94samson
Have a 1997 SPX and the thing will not turn over with the spark plugs installed, take one plug out will turn over slowly. Take both out and it will turn a little faster.
Here is what we have done:
Have 5 other models and tried batteries out of starting running skis same issue.
Ohmed the wires from the battery to solenoid, battery to ground, solenoid to starter, all zero.
Cleaned every cable end listed above.
Jumped solenoid starter and motor spins right over
Replaced solenoid
With new solenoid, left wire off that goes to starter, hit start button and get 12.7v on the starter side of solenoid. Connect starter wire to solenoid leaving wire disconnected from starter, test starter end 12.7v. Connect to starter and same issue.
Jump new solenoid everything turns over like it should.
Original solenoid has metal base, the new one has plastic base. So tried known working used metal base solenoid, same issue.
Pulled starter to test it, cannot find specifications to campare to.
Cleaned contacting surfaces on starter and block.
Reinstalled starter and same issue.
Hit the start button and the motor barely cranks, remove plugs and goes faster, only turns over quickly when jumping solenoid.
any ideas?
Replaced solenoid
any ideas?
