1996 hx HELP
Pat O'Brien
Just got two seedoos the 1996 hx seems to be missing steering nozzle,battery, starter relay, could be missing more.Dont know... Just want to know where to start. should I drain all the oil and gas? what else do i need to do?One thing I saw was that where you hook up the hose to run it out of the water had dirt dobbers in it . Lots of mud. How do I clean it out? It has sat for at least 3 to 4 years.
Pat
It sounds like you have your hands full. Here is the best advise you could have.
Here is some more information on the "Premium Membership";
As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
