Hello all.
I have a 1996 seadoo gtx with a rebuild 787 motor. It runs gd. but will only run about 47 mph. Is this normal for the year? I ave noticed that my plugs are black and a little wet so maybe I need a carb adjustment.
I took off the jet pump to check out my wear ring and impeller. The impeller has little nicks on the blades. Not the blade edge that goes againts the wear ring but the other edge. Very slight nicks. I used a file and cleaned them up. The wear ring just has some scratches, but no gouges, or anything. I measured the clerance between the middle of the impeller edges and the wear ring and its about .30 to .40 mm. Is this ok??? I have noticed that it tighter on one edge than compared to the other. (I measure at different spots ect. 9 oclock, 12 oclock ect. But never more that .40 mm. But it def had a little fluxuation. Is this ok? Also can I use black silicone to seal the pump to the housing when I put it back on the ski? any suggestions on the back wet plugs. I just had the carbs rebuilt by a reputable seadoo dealer. Also, I was going to change the pump oil while I had it out. Can I just take off the alen key bolt, drain it, and fill it back up again on my work bench? How much do I put in, or do I fill it to the top.
Thanks for any help you guys can give me.
