My son was riding the Seadoo and when giving it throttle it died & would not start afterwards. Engine turns over fine with no weird noises but no spark after charging/testing the battery (>10.5V when turning over). All fuses were good. Took apart the rear electrical box & found a little corrosion on some terminals. Disassembled & cleaned everything up. Tested the ignition coil (primary was 0.5 ohm & secondary with caps off was 12.3k ohm which seemed to match the specs). Plug caps measured 4.96k & 5.84k ohms (although the one that tested 5.84k didn't give consistent readings). Also tested the lanyard, start/stop switch, & delay timer (all appeared to be good). Put everything back together & same issue - no spark. Tested at the plugs with no spark & also did not get DC voltage at the white wire going to the ignition coil using a 12V automotive test light.
I don't have a trigger coil test harness to check for output at the magneto housing (ohm or AC Voltage). Not sure what to do next - wondered if there was a way to test this output without a test harness. The repair shop mentioned that they would likely pull the engine to remove the magneto housing to test the trigger coil & stator. Wondered if you can advise on any other tests or recommendations I can do myself before taking it to the shop & having the engine pulled (since I really don't want to try pulling the motor myself).
I also couldn't find any articles on removing the magneto housing while it's still in the hull (and if it's advisable or not). There was a reference to being able to do this (putting 2x4 under the engine & removing the front engine mount) but really no concrete instructions for doing this while in the hull. My other concern with trying this in-hull was if I could possibly mess something else up (eg the oil pump/system or having to adjust timing).
Advice would be appreciated. Thanks!
