1996_GTX_Owner
Purchased used 1996 GTX 787cc in really nice shape with a starting problem. I installed carb rebuild kit, new plugs, drained old fuel and installed new battery. Now able to start but was running rough. Did plug readings, front cylinder was very lean adjusted high speed jet until nice brown plug color like rear cylinder. Compression test on cylinders are equal at 155 psi. When riding, a miss is present unless on mirror smooth water in straight line. Thought I had a fuel pickup problem, but today I discovered during out of water running while hooked up to water hose that ski runs fine at idle and troughout rev range. The problem occurs when the ski is moved from side to side or rocked on the trailer (very little movement rquired), the ski immediately stalls as if a kill switch was pushed. Starts up again and runs correctly, but the stight motion continues to immediately shut off the engine.
Is there some sort of inertia switch or safety switch that shuts down the motor on detected roll over? I have checked all electrical connections etc trying to find the problem, but problem persists.
I'm a long time motocross rider / hot rodder and repair all of my own vehicles regardless of level of complexity. This ski is ready to ride, I'm eager to wring the thing out, but this problem has squelched and chance of enjoyment to date.
This problem has be stumped, any assistance would be greatly appreciated.
Thanks in advance for you reply
Bill
Orlando FL
Bill
Orlando FL
