gazzaskirepair
No t cheap that’s why I said if stealership had it off they should of aligned engine
You could remove pump and shaft and ask them to check alignment as the pump and shaft is off it should be cheaper
Under an hour to check and no more than two hours to adjust
Requires shims to adjust
