I got a 1996 gti 720 rotax and idling throught the no wake zone all is good I get on the throttle and up to plane and the temp light and buzzer goes off. I know its not too hot cause I stopped to check it and the motor is only warm to the touch but not hot. I took the sensor out of the top of the head when I got home and with it plugged in and not touching anything it is good but when you touch it to any metal it goes off again. Is this a bad sensor or should I look for another explantion. I checked to make sure the water was going through the head and wasnt blocked. Also the water inlet seems high on the hull to me ontop of the jet pump. I assume it is factory like this but it seems like that part of the ski isnt in the water enough to suck it up and does the exhaust create the vacuum to get the water to the motor? Thanks in advance!!
