K Huf
I am new to the Seadoo scene but I have been boating for years. I picked up a pair of Seadoo PWC's, 1996 GTI 717 and a 1994 GTX. The GTX engine is in pieces so I am focusing on the GTI. The issues I am having are as follows.......
Initially when I connected a battery it blew the 5 AMP fuse. After a series of tests I found that it only blew if the magneto was plugged in. Figured that the stator was bad and pulled the flywheel. The stator and flywheel are very clean so I figure they may have been replaced recently. Connected the battery and the starter spins but only with the magneto plugged in. And now the 5 AMP fuse no longer blows. Re-installed the flywheel and it cranks and fires on starting fluid but after releasing the start button it is totally dead unless I unplug the magneto and plug it back in. When I re-connect the magneto plug it starts to crank without the start button being pushed. Then it will crank again. Compression is about 130 PSI on both cylinders.
Not sure where to go from here.
