Deepcove1
I have a 1996 Challenger with the 787. I rebuilt the top end, added fresh carbs and fired it up.
It will not run except on very rough idle. I noticed a lot of black oil discharge in the exhaust.
This appears to be the 30W oil from the countershaft. I removed the oil filler cap for the counterbalance fill hole, and jammed a hose tightly into it. When I blow into the hose, I hear the air leaking thru to the PTO carb, so obviously the 30W oil will drain into the PTO crankcase.
Does this imply that the seal on the crankshaft next to the PTO side gear is the culprit? There is a seal on the counterbalance shaft as well, but there doesn't appear to any connection otherwise into the crankcase that way.
How difficult is this fix?
