1995 XP 720 Restoration
Did you make sure you have continuity on the little ground wire that goes to the battery, into the black ebox and down to the coil where all the grounds terminate? You can crank all day with no spark if that wire isn't grounded. Those plugs are common for corrosion.
I don't see it in your picture but make sure you run the OEM carb brace so you don't crack your intake manifold.
Yea that's cold. :D :D I'm gonna ride a couple next week. I gotta get these things WET !!
Haven't done any jetting yet, but I did get that seat cover done. I've gotta get an alignment tool and align the engine and install the jet pump, then its DONE, atleast until I can get it on the water and do some jetting as well. Gotta get a VTS module as well. I think the one in it is shorted out.
Hope you all enjoyed the project and the finished product.20190222_195121.jpeg
