I recently picked up a 95 spx for a cheap deal as it wouldn’t start. previous owner had it out the season before but was having trouble this year after a new plug and battery. The start button will only crank the engine a few times but would cut out before it would turn over with or without plug. I sanded all the battery connections and starter leads cleaned all the grounds and connections to the solenoid and still couldn’t get it to keep cranking.
Battery is new and I have also tested with a larger marine battery with higher CCa with no luck.
The starter will only stay engaged if I jump the solenoid terminals.
I’m starting to think either bad sol. trigger from Mpem or a DESS issue ( no beeps when lanyard is attached didn’t think DESS was equipped on the 95 but I can press the start/stop button 5 times and get the diagnostic beeps)
Any suggestions would be helpful.
