So I just bought a used 1995 SPX...I have no idea what Im doing as I have never owned any watercraft...heres the deal..
Eveerything was running good when I bought it from a guy...I got home and tried to flush it with the hose....I hooked the hose up and turned the water on and then tried to start the jet ski.....I kept trying to start it for 4-5min with the water running and then realized I must be doing something wrong....I looked up a DIY article today and saw it say "Start engine before turning on water. Do not turn on the water. (IF you force water into the motor without it running, water can and will backtrack up into the carbs and cylinders causing hydro-lock.).....
So Im assuming that i caused "hydro-lock"? Is there any way to fix what I did?
Thanks
Thanks
