I have a couple of 1995 SPI seadoo jet skis with not many hours. They both ran great, until 1 day one went from running great to sluggish. I put a new gas filter in, that is just under the dash or hood. I put a new oil filter and plugs in also. It idles great, and I can rev it up good also. I get on it, and floor the gas, and it take off great, and runs fantastic for about 3 to 4 secounds, and then goes into the sluggish mode. I let go of the throdle for about 3 seconds, and floor it again, and it does the same thing. Runs fantastic for 3 to 4 seconds and go to sluggish.
I have been hearing about the gray fuel lines, and do not know if I have those or not, because the skis are not here right now. I know they are the original lines that came with the machines. Could this be my whole problem? Also, if they are gray, do I have to clean out the gas tank & baffle, or just the carbs? Does the SPI's have another fuel filer somewhere. Like in the carb.?
2) Both machines gas guages broke the first year. Is their a cheap fix for this, that will last, or are they known to keep breaking?
THANK YOU VERY MUCH FOR YOUR HELP
K A Z :cheers:
K A Z :cheers:
