Hello,
I recently tried to repair cavitation in my Port side engine. Prior to repair, When excellerating upto 5500 rpm the engine and pump run just as expected. As soon as the rpms go over 5500 the pump cavitates and the rpm jump to 7k and bounce off the rev limiter.
Now, having a little experience with these boats, I ordered a new OEM wear ring and a drive line repair kit. (http://www.sbtontheweb.com/Merchant...0-101&Category_Code=1995sdsp&Product_Count=16). I did a full pump rebuild, installed the new wear ring, and the drive line repair kit. I fully expected this to fix the problem.
However it did not. After water testing the motor it was apparent that the problem was still there. Same problem, runs fine to 5500rpm then jumps to 7k and bounces off the rev limiter.
Anyone have any ideas? I thought the parts I installed would correct any cavitation whether is was the wear ring or sucking air through the ingine compartment.
Is this how all 1995 speedsters run? seems unlikely.
Any ideas?
Tyson
Any ideas?
Tyson
