1995 speedster.HELP
yates2k5
i just bought the boat. i need to find a throttle cable for the left engine.
does anyone know where i could get one?
Also the right engine will fire up when you first try and crank it; but whenever i get out there and shut them off and then try and recrank,the right engine will not fire up. it turns over, just wont commit and crank, i will hold the start button for a few seconds and it coughs like it wants to crank but wont.
do a google search for seadoo parts and you'll find a bunch of places. As far as the engine not starting, do you have spark? Have you changed the plugs? Are your fuel filters/carbs clean?
pull carbs, stud...just to eliminate that possibility, and go thru them.
As for throttle cable, I have 2- brand new ones for 98 Sportster 1800, which the driver seat configuration is the same, along with motors' placement. If you weant, take measurement of the cable, then pm me, and see if one's i got, will work. Almost certain they will. Saw that the left one, is "obsolete"
