95SpeedsterPat
Hi and thanks for your help in advance!
I just bought a 95 speedster and I'm trying to figure out the issue.
1st - the neutral kill swith was making starting unreliable, so I had it disabled by a guy. I guess aligning to neutral was an issue, so this was an easy solution.
2nd - It was 'bogging' or somehow maxing out at 4k rpm. I was told carbs, so I had them taken apart, cleaned, sycnched,etc
3rd - I picked it up yesterdayand tried it out of the water and it would not go past 4k rpms at full throttle.(I know you can only run for a few mins out of the water)
So, I was reading on another thread that these have a rev limiter. I'm wondering ...
(a) if disabling the neutral kill switch may have this rev limiter permamnently engaged and ?
(b) Can I disable it?
(c) any other ideas??
Thanks again!
Thanks again!
