jimmyluke
I’m putting the carburetor back on after a carb rebuild. In order to get the oil pump set as close as possible now, I would like to know how many turns inward after the idle speed screw touches the lever is a good starting point?
Also I’ve read a number of places on the forum that you recommend 3000 RPM out of water. My manual says 2400 RPM for my 587 model SP. Which do you suggest?
Thanks Jim.
Thanks Jim.
