1995 Sea-Doo spi carb removal
Leecamo_5
I am currently taking my carb off of my spi and have trouble getting the nuts to budge on the bottom of the carb to completely remove it. I have gotten all the throttle/choke cables undone and need to know what size wrench to use and best way to get in the right spot and loosen it up.
That might be one of those that you have to remove the 4 bolts off of the intake manifold with the carbs still attached. Just ran through this on a 94 gtx. It was a royal PITA.
Make sure you get a new o-ring for the intake manifold if you took it off.
If you did it wrong and removed the rotary cover you better make sure the rotary disc didn't fall off and come out of time.
Never got that far into it so I believe I am good. The timing seems to be good on it I am gonna take it out soon I’ll let you know how it’s running!
