1995 gtx Gauges
joey1994
Recently i fixed up my grandfather's 1995 gtx after sitting for over eight years, we rebuilt the carbs and fixed all the broken cables and she runs great. The only problem is none of the gauges work. It has one digital all-in-one gauge, and one speedometer. I have checked and replaced the two fuses in the gray electrical box and I see no loose wires. It appears as if the system is getting no power at all.
Any help is appreciated,Thanks
With the battery hooked up you should be able to hit the start stop button and the four lights will light up red. This will let you know if you have power going to the gauge. The display in the middle is just a bar gas gague. If this does not work and the gas red light stays on all the time do a search. Lots of good info on this fix. If no power just start by going over all connections, cleaning and putting back together. Sitting this long it will probably be a little coroded. CCC
