SIMPLEARKANSAN
So a week ago ski was running. Removed the gas tank and oil tank to flush and clean. Replaced oil filter. Bought appropriate Seadoo oil and fresh gas. Originally had a bad solenoid. Replaced it and all cranking issues resolved. Decided to give hull a good washing inside since gas tank removed. Battery was unhooked the entire time of the cleaning. Before putting tank back in I thought I try to turn engine over. When you push the green start button there is no crank or solenoid clicking. VTS buttons work for a few seconds after attempting start. I was afraid I may have gotten water into the front Ebox. Checked it and dry. So I thought maybe the switches had gotten wet. I took air compressor and blew them out. I checked continuity on the start switch, the lanyard switch and the red kill switch. All were good. Checked continuity on ground wire and red wire from solenoid to the starter and both were good. If you jump the solenoid it will crank engine. So I thought bad solenoid. It was a used extra I had. So today I replaced with a different used solenoid same symptoms. When I push the start button neither solenoids will provide power to the starter with a test light. I checked all fuses and ohmed them good. So I have a new solenoid in the box. I’m thinking that will be my next option? There were no problems before I washed the ski’s interior. I’ve also checked grounds in the EBOX and they tested good also. Thanks in advance for your assistance.
