94seadooGTX
Alright everybody, I have a 1994 Sea-Doo GTX. I am having an issue where the machine suddenly dies (almost like I was hitting the kill switch) it dosnt bog or somewhat stutter and stay alive like a fuel issue would typically indicate, it just dies. I would be screaming across the water at WOT and it would shut off, I would quickly hit the start button before the machine even gets off of plane and it would fire right up and keep going like a rocket. It would keep doing this. Now it seems as if the time interval from when I start it and it kills seems to be getting shorter and shorter. Carbs are clean and diaphragms are in excellent shape, all fuel lines have been replaced, rectifier is new, and engine has good compression (if my memory serves me right both cylinders were between 140 and 145 p.s.i.), I tested the mlps according to the shop manual and this is what I found. Each test gives an acceptable resistance value range. There were 3 of the 7 readings I took that were out of spec, they are listed below. By the way I made sure to complete disconnect all of the leads going in and out of the mlps prior to testing.
The first wire color listed is the one I hooked my - lead on my multimeter to and the 2nd wire color listed is the one I hooked to my + lead.
Yellow/Red Red ring terminal. Minimum: 150K ohms Maximum: 1M ohms My result: 1.508M ohms
Black ring terminal Purple female connector Minimum: 100 ohms Maximum: 1.2M ohms My result: 1.67M ohms
Black Black/red male connector. Minimum: 200K ohms Maximum: 1M ohms My result: 1.29M ohms
Any guidence towards a solution would be greatly appreciated thank you!!!
Also, it seems like it dies more frequently the higher the RPM, if I run it at let’s say 1/8 throttle it will run much longer than at 1/2 or full throttle before dying.
