I have a 1994 GTX that I bought a few years ago with a piston with a hole in it. Last year I replaced the pistons and rings and fuel line and cleaned the carbs. I finally got it all back together and am running 40:1 pre-mix with the injection system. The engine starts easily and idles perfectly. When the throttle gets above about 10-25% it runs very rich. It spits fuel out of the carbs and sounds like it is just bogging down. It does rev up, but it sputters. It even back fired a couple of time. I double checked the rotary valve and that was fine. I set all of the carb settings to factory. What do you think it could be? Carb setting issues? Thanks.
