Geoff240ti
I've got a 1993 Seadoo.. unknown model. It has a 587 dual carb.
When I go to start it, it cranks with no spark. If I take the tether cap off when I crank it sputters right when pull the tether cap off.
I figured it's just a bad switch, but I ohm out/tested the switch and it is perfect (this goes for the handlebar switch as well)
Now if I want it to run I need to use my finger on the post and work the switch a couple of times when it's cranking. After a couple kill switch cycles I can put the tether back on and it'll run.
Is this something with the stator? Is the MPEM failing and not exciting properly but it does when the ground loop is interrupted? I have yet to take the machine out until I get this figured. I'm not sure if something will fail and strand me on the water.
I have searched and found one previous thread with this exact same scenario but not answer on fix. The fuel system is all gone through and I'm ready to roll once this is solved. If anyone can shed some light it's greatly appreciated!
