RESTO 1992 SP Missing a drain plug, What is it supposed to look like?
chrisorbics
I have a 1992 seadoo sp that is missing a plug in the rear to the left of the jet drive. I can not find any pictures of what it is supposed to look like and I am looking for a replacement. I assume it is a water drain plug.
I got the waverunner with a locked up jet drive. The jet pump housing was corroded pushing the wear ring into the prop. Someone thought it was the engine and unbolted the cylinders. So I honed cylinders and did a wsm top end kit. It was still standard bore and very clean. This waverunner has very little time on it. It has really been sitting forever. The bottom of the hull is like new. Definitely worth the mini restoration in my eyes.
The exhaust and engine are so clean. I will have to post some pictures.
Walmart, in the boating section
https://www.walmart.com/ip/Attwood-Snap-Handle-Drain-Plug/16351049
Thanks. I guess I was over thinking it. I am used to the screw in type. I thought I was missing a whole housing LOL.
The engine is rebuilt. I just rebuilt the carb and replaced all of the small oil injection lines. I have to clean out the air box lid but I can do that after the engine install. I have to pull out the power washer and clean the hull out good. I was very clean but when I pulled the engine a lot of oil spilled inside. I want this sp to be super clean. It might not be fast but it can be clean.
