Lelandridesrotax587
How much?The same place your new one came from. Skat-Trak does an excellent job refurbishing them.
Dang it lol you shoulda gave em to me lol I could use a couple . But I think I got a good dealI think basic referb is around $70 to get it back to true. But I wouldn't bother with an aluminum prop. You can get stainless ones on eBay for probably less than rebuilding yours at Impros. I threw away a bunch of impellers recently when I moved, as I had no use for them, and no time to sell. 580 parts are the cheapest online.
Also a stainless steel one is 170$!!!!!!!!!!!!! I’m 14 and I can’t afford that lolI think basic referb is around $70 to get it back to true. But I wouldn't bother with an aluminum prop. You can get stainless ones on eBay for probably less than rebuilding yours at Impros. I threw away a bunch of impellers recently when I moved, as I had no use for them, and no time to sell. 580 parts are the cheapest online.
Well, technically, you only need one impeller. If you ding it up, just send it off to get fixed. I think it takes about 1.5-2 weeks to get it back from the day you ship out. Knowing how this pump system works should teach you to stay out of the shallow areas. I see so many people carelessly ride in half a foot of water, or run new skis up on the beach. I just shake my head.Also a stainless steel one is 170$!!!!!!!!!!!!! I’m 14 and I can’t afford that lol
Thanks, I appreciate the advice! I’ve had many different vehicles in the past but the jet ski idea is still pretty new to me so the advice is very helpful!Well, technically, you only need one impeller. If you ding it up, just send it off to get fixed. I think it takes about 1.5-2 weeks to get it back from the day you ship out. Knowing how this pump system works should teach you to stay out of the shallow areas. I see so many people carelessly ride in half a foot of water, or run new skis up on the beach. I just shake my head.
That's really cool that you're learning all this at such a young age. I too was 14 when I started wrenching on SeaDoos, and also had a 91 SP. We had a 92 GTS too, which was basically the same ski but a 3-seater. I had that thing up until just 2 years ago. That thing has been everywhere, from the lakes of North Texas to Key Largo. They're great skis to learn on, very forgiving, and by far the most fuel efficient in the seadoo 2-stroke lineup. I think you have the perfect ski for this period in your life.
. Is this just a super crappy wear ring? It’s plastic.......Well, technically, you only need one impeller. If you ding it up, just send it off to get fixed. I think it takes about 1.5-2 weeks to get it back from the day you ship out. Knowing how this pump system works should teach you to stay out of the shallow areas. I see so many people carelessly ride in half a foot of water, or run new skis up on the beach. I just shake my head.
Ok, how do I remove the impeller!?????????? I’ve been reaching on that hunk of junk all day, no luck even bent a bolt as big around as 1/4 inchNope, it is a stock wear ring that has lost the rubber. Pretty common on old pumps. And don't bother with that impeller, it isn't worth the money to fix.
I tried that with a bolt that has held but it bent it...... don’t really want to spend $10 more bucks for probably a one time thingYou will need to get an impeller tool that fits the splines where the driveshaft goes into the impeller. THen you pull the pump cone on the back and you will see 2 flats on the shaft you can put in a vise to hold it.
To install it too?What "Bolt" did you use? You have to use a spline tool to unscrew the impeller. You are also going to need the tool to install the new impeller.
Yeah...... it’s so annoying though. Seadoo was like let’s see how hard we can make it for morons.... lolWe are talking about removing the impeller from the pump correct?
Ok I got all that done however I chipped one of those fins in the housing. Will this effect performance?So basically you have to pull the rear cone off the pump(three8mm bolts), a bunch of stinky oil will come out so be prepared. Then you put the flats of the pump shaft in a vise.
Then you use the impeller tool to engage the internal splines of the impeller so you can use a socket and breaker bar to unscrew it.
It unscrews with standard threads, counterclockwise.
Ok, he lets me drive it on the pond now, it doesn’t oil up the water and he has some oil. And yeah I got a wear ring hopefully will last. It’s not an expensive one.Also, you'll be changing that oil in there. I used 75w-90 synthetic. If you've got some car or boat guys in your family or friends, they may have some. It doesn't hurt to ask..you don't need much.
messing around with stuff. But I think it’s okYou need probably need to replace the shaft seal as your oil has water in it.
How dd you chip the stator vane?
