tonytheteeth
Hi all,
I'n new on here and to jet skiing for forgive my inexperience please.
I have a 1990 sp and it seems to run fine however if i push the throttle to more than half open it revs and the rev limiter (i asume) cuts in. The ski seems to have power in the water and seems to go fairly quick but something is obviously wrong. I have tacho'd the flywheel on the trailer and its hitting around 5400rpm every time and then the rev limited cuts in and out as you would expect, i do seem to be getting these revs on the water too. I have checked the intake grate and visually checked the impellor/wear ring clearance (looks about 0.5 - 1.0mm) Any suggestions please?
Many Thanks
Tony
Many Thanks
Tony
