I got this thing for $250 off CL. It needs paint & the graphics are long gone...
Also, the oil tank is gone, so I'm assuming it was converted to premix....
That said, compression is strong, it turns over freely, and I got a sealed AGM battery to replace the dead harley-battery that came with it... I'm assuming the carbs need cleaning but I'll hit that up after I fix the major issue... Which is:
NO SPARK.
Being somewhat familiar with Denso CDIs (and being glad this is a pre-MPEM unit, with separate CDI, rev-limiter, and coil), I've done the following:
1) Checked grounds - when I got it, the brown ground was disconnected inside the flywheel-box, it has now been reconnected
2) Bypassed the entire rev-limiter/stop-switch/lanyard-switch assembly, by connecting the battery-+ wire that goes 'up into' the handlebars, directly to the black wire that comes out of the rev-limiter to power the CDI (fortunately, they snap together w/o any modification).
While I can't run the ski that way, I can diagnose spark that way & re-connect everything after I have a good baseline.
3) Checked connections of all the wires down in the flywheel area.
At this point, there is still no spark.
The ground side of the coil-output from the CDI tests good.
The positive side has no voltage when not cranking, and a small voltage when cranking (measured with a MM connected between coil+ and ground, coming out of the CDI.
I'm thinking bad coil...
Any other ideas?
I presume that because I'm getting juice out of the CDI's coil-driver line when the engine cranks (but none when it doesn't), that the pickups and CDI itself are working.
Am I missing anything, or should I try a spare coil (I've got some 2-output coils from a GS-850 bike, which also uses a Denso CDI - they should work for test purposes)???
Any good guides for CDI testing with a multimeter, as opposed to Seadoo 'special tools'?
NO SPARK.
Any other ideas?
