1989 seadoo, the beginning
wjd03
Hi all, I am brand new to this forum and I am learning my way around. Just got a seadoo off Craigs list....FREE! Of course I know nothing about it other than the carbs are off and apart. I am looking in threads on putting them back togather, however as I know nothing about these, I will probably ask 10,000 questions. I dont know model or engine so when going thru threads, I seem to get lost. Any welcoming info would be great. I like to use the search button and see where folks had similar issues, but not knowing anything about this thing has me looking for simple starting points.
Thanks,
You came to the right place!!!!
Thanks,
Well, welcome to the forum. I should say, you came to the right place for info. Surprised to see that you can still find one of the original skis. The Seadoo actually first came out in 1988 but sold in 89. Your model ski is the SP. It was the first model of many in the later years to follow.
If your ski is all original, the engine should be yellow. This ski uses the yellow 587cc engine with the single Mikuni carb set up. You'll probably run into a time finding parts for it, since most parts for this ski have been discontinued. That doesn't mean you won't find some parts, because you will. You will still be able to find carb rebuild kits and even a newly remanufactured motor, if you need one.
The first thing I'd do is a compression test. If you basically got it for free, before you dump any money in it, you need to know what shape the piston and rings are in. You can buy a compression gage at any auto parts store for about $25 bucks. You will use it more than once, so if you don't have it, get it. Though compression on a new motor is between 140 and 150 psi, it's most important that the pressure spread between the two is 5 psi or less.
If you have good compression, the next thing your going to want to check is spark. Take a spark plug and attach it to the wire. Lay it down across the head of the engine (on a shady, overcast day or inside the garage to see the spark) and push the start button. If your coil and ignition module are good, you'll have spark on the plug. If not, then you'll need to trouble shoot this right off. Replacing the module may cost you more than the ski is worth.
So, take steps in that order and let us know what you get. This info is enough to get you started.
If you really want to learn something, use your PayPal and sign up for one month to get premium services. You get one on one service, a manual and help to premium members comes first.............:cheers:
re thanks
Thanks for the welcome seedosnipes. Yea, free on cl....I am just trying to fam myself with this thing. The guy that gave it to me told me the carbs need rebuilding, (we shall see) but I dont know we shall see. It has dual carbs, is this standard? Also, another piece that looks like a carb (must be an oil injector) apart-dont even know where it go's! And to boot, dont know where the Battery is located. Great site!
Thanks
looking into it
It looks like a mod was done, single carb swapped out for a dual carb setup. I can see a plate to remove and replace with the original carb which I also have. then its running gas and oil lines baCK IN. Still wondering about the Battery location.....
You should look around the carbs for numbers like 38 or 40, and the skinny plastic lines are the oiling lines from the pump block to each cyl valve port, one thing that took me a year to understand is the rotary valve function - it is a marvelous thing when it works correctly, and a note on electrical things - never ever hook your ski to a running tractor, car or battery charger, substitute a known good battery, the overvoltage surge from a running car or charger will damage the electronic stuff that is the spark control - once this is done the spark box is kinda useless - everyonce in awhile a repairman shows up who can fix some of the older ones and finding good old ones is pretty hard to do as these have been cast aside in favor of the 4 cycle machines.
