1503 scic
yada
was doing a build just to see , checked out the info button on motors and got the base 900 and the ho and this which though stated is not listed yet,, makes a guy wonder what seadoo has in the works for next year or a late build >>>
Engine
Rotax 900 ACE/Rotax 900 HO ACE - This is an 899 cc four-stroke engine, with three cylinders and four valves per cylinder. It allows for the creation of the most compact and lightweight engine on the market. Built with the acclaimed Advanced Combustion Efficiency technology it’s also the most fuel-efficient watercraft in the industry while still delivering excellent power-to-weight ratio.
1503/1503 NA - Each Sea-Doo watercraft comes equipped with a legendary Rotax® 4-TEC® engine, specifically designed for marine use. Not only do you get quicker acceleration and a higher top speed, your Rotax engine also works hand in hand with iTC to provide more precise engine calibration. What this means is better fuel economy for you.
1503 HO - Provides reliable, ultra high-performance in salt and fresh water, giving you more power and efficiency.
1503 SCIC - This Supercharged Engine offers more power than the Yamaha VXR and VXS*. *Source: Air Resource Board website.
