Hello all, please help:
Was just given an 07 GTX 155 4 Tech by a friend who bought new, barely used it, and then let it sit a couple of years. Not a mechanic but do maintain two boats and have a friend who builds race engines but does not know Sea Doo’s. Though this would be, and is, a great project for my sixteen year old son and myself, however, we have been stumped.
Knowing it had been sitting for so long we immediately
Drained fuel
Changed spark plugs
Changed oil and filter
Put in fresh fuel
She started right up on quick connect. Note...very aware that engine needs to be started prior to adding water as well as stopping water before killing engine. Should not run more then a few minutes, which is what we did.
Excited we took it to the launch and I idled out to the river, with the occasional bump of the throttle, again excited as it was very responsive.
Throttled down to take off, it gladly accelerated immediately, and just as quick sounded the never ending beep with the oil symbol, on lower left of display (Did not see that at first as display is kinda dim. Remove key alarm stops, starts right up, idles perfectly. Repeat scenarios three times and then with glasses see the oil symbol.
Idle back to dock, check oil, and it is milkshake. (Chased this problem on my 525efi and finally found inversion from the broken flaps)
Have drained oil and pressure tested the cooling (antifreeze) system and that is fine.
Pressure tested the cylinders and all were 150
According to my mechanic friend who helped me with the cooling system check, performed by vacuuming one line and plug on the other, if there was a leak internally on the oil cooler, then pressure would have not been held.
Where else can water come from? His theory was that all that sitting over a couple of years could have allowed internal moisture to build up, however, when we drained the sitting oil, it looked crappy but did not have water in it. At a loss and appreciate any and all help. Thanks!
Drained fuel
Changed spark plugs
Put in fresh fuel
