Shacho
07 GTI SE Pump Housing Jet Nozzle Parts
Before I take my GTI out for first time this year, I'm curious about whether or not the pump housing jet nozzle reverse gate, arm, rod pivot, and triangle parts are worn or is it standard installation for all parts mentioned to have some play due to the spacers installed etc? All the nuts and bolts are tighten/torque according to the specs.
BTW - what's the advantage to having the cast iron/steel pump housing ver the plastic pump housing beside the easy removal of the wear ring with steel pump housing?
