07 Gti Drive shaft
s91wff
So I replaced the carbon seal do to dust after a filed down my impeller. I’m guessing I made it out of balance and that’s causing the dust as there was none prior. So it and the impeller got replaced. I don’t remember if the (grove) near the engine goes into the bearing or stops short. Any information would be great as I don’t want to launch it yet till I have confirmation. dba5e540b0f26b0e7fdfd70f4dd1d7df.jpg
Props don't really get "imbalanced),,,not sure of your (dust)?,,,if you take the boot off your pump( reverse thread),,and try to install the pump...you!ll know if the shaft is not in far enough.
