06 RXP - Key Issue
Joester
I use the yellow key for the RXP and after hitting the engine stop button and removing the key the beeping continues. Anyone had this issue in the past??
As always, thanks for your help in advance.:thumbsup:
Ok,, so the DESS acts like there is still a Lanyard on it, but not the right one..
It is nothing more than a magnetic reed switch. That said, the MPEM reads the Lanyard via the DESS.
Tap on the DESS while it is running with a screwdriver handle and keep tapping on it while you pull the lanyard off. I'm curious to see if the Reed is week or stuck.
I will check this when I return from offshore on Friday and will send you an update there after. Thanks for the help!
