Jerrid
Hello everyone,
So I've been searching the forums and have seen a lot of people have had similar problems, but not exactly what's going on with my 2005 3D. The ski starts up fine, idles fine and at less then half throttle runs great. At half throttle while driving it will go then kind of bog down then go again and bog down again. Pretty much like the RPMs are dropping then raising back up to where it was. It will also happen when going from half throttle to WOT, when it happens if I let of the throttle completely and WOT again about 90% of the time it will take off without any bogging/hesitation. I already have taken the fuel pump assembly out and replaced both internal and external filters. ( tank was clean) removed and clean the RAVE valves (also replaced the o-rings and gaskets) and installed a new oil filter, and spark plugs. Took the ski out last Saturday and it was still bogging/hesitating.:facepalm:
Figured I would see if anyone has any advice, before I decide to take it into the dealer.
Any advice would be greatly appreciated
Thanks Jerrid
Thanks Jerrid
