Duane72
I posted in a nother thread the overall issue with the machine not starting. TO save a lot of not-needed reading I'll say this is where I am at. New plugs, coils are fine, fuel is fresh, fuel pump operates, cleaned all ground connections on the block and battery. No codes and brand new battery.
That being said the engine turns over fine when you try to start it. I get some ignition but not a full start up. I pulled the throttle body and cleaned it good, including soaking and cleaning out the passages to (and hopefully the sensor itself) the Idle Control Valve. Put it back on and the engine REALLY wants to start. It fires just enough to the point of over-running the starter (when you would normally let go of the start button because it's running). When the starter disengages the engine stops. It won't keep running on it's own.
Pull the plugs and they are a carmel color, but not thick with it. Some brake clean sprayed on them and they are clean as new and it starts all over. What could cause the engine to be so rich right at start up like that? Is there a choke of some sort on these machines? It's not a manual one I know that.
It's a 2005 RXT Supercharged.
I'm right on the brink here of getting it running!! PLEASE, any advice is welcome!!
Duane
Duane
