Mr. G
Hi i am new to the DI skis and need help bad but i will try to keep it short. Bought an 02 RXDI that has been sitting since 05 with only 50 hours but crank was wiped out. Rebuilt the engine and the ski ran good but would usually start hard (hit the button and it would pop for a second and die) about 5-10 times and then it would idle and run good until you backed off the throttle it would die but you could restart it right away. Ski would foul out plugs and they would be really black but after changing them it ran great. today i had it out wide open for about 2 minutes and it ran about 6750 rpm but a little funky so i pulled over and it died. changed the plugs (which werent black this time, nice tan inside like they should be!) and it wouldnt restart, just pop for a split second and thats it. Felt like it wanted to but didnt. Fuel pump runs and sounds strong, has spark, plugs out fuel is spraying from injectors etc. I know cars very well (especially injection) but am new to DI seadoos. I am thinking about checking the fuel pressure tomorrow and am not sure what it should be (i heard around 90 psi?) could the funny starting and running issue i had before have gotten worse and now it wont start at all? rave valves are closed, compression is good, no funny beeps, only if i hold the throttle while cranking which i believe is normal. Battery and solenoid are new, new key D.E.S.S. from seadoo etc. Hopefully someone can help lead me in a direction since i want to ride it again. I thought about bringing it to have the ecm scanned, but i unplugged many things trying to diagnose it and am afraid of false codes. thanks in advance
Greg
			Greg
