02 GTX Limited had a lot of smoke. Too much oil in engine, drained oil and filled correctly it still smokes and runs rough. Checked the compression and it is jumping around from 145 to 180 in each cylinder. I pulled the valve cover off and noticed the Chain Guide Tension and Guide Chain were both destroyed and the chain feels rough. Could this be causing the compression changes? Should I change the chain and guides? Do you think this could resolve the issue? Looking for input as I don't want to go deep in the engine unless I have to. I have put a camera in the cylinder and the pistons appears ok.
