LONG TIME lurker, first post.
My 2002 GTX DI was running awesome until about a month ago. It has 230 hours on it, and I've always kept maintenance up on it - I have the shop manuals and follow a lot of the suggestions from this board.
I put the ski in the water after filling up with 100% gas, and it ran great for a half hour, then bogged and died. It started right back and slowly started to run rougher and was turning less and less RPMS (all of this happened within a minute). It quickly was running so poorly that it would start and idle for about 5 seconds, then die. I let it sit and took it out the next day to work on it. Ran great for 3 minutes, then the same quick loss of power and 5 second intervals that it would run.
I pulled the plugs, totally fouled (BLACK). I pulled the fuel rail and checked things. I soaked the tips of the injectors and cleaned them. The rave valves are nearly polished, plugs were replaced, fuel pressure 107, cylinders 123 each. Ran it again, same thing... 3 minutes of run time, then bleh. Fouled the plugs again in that short amount of time.
At no time did I get an alarm or limp mode.
I took it to a place in Knoxville, they plugged up and saw some fuel rail related codes (wish I would have asked for specifics). They said that an o-ring on the fuel rail was in rough shape, so for $215 they replaced it. Apparently shop towels have gotten expensive. Got it home, same thing. Ran like crap. Took it back, and they said the stator was not putting out full output - quoted me $1100 to replace, so I did that one myself easily. One phase of the stator was reading 1.1ohm, so technically out of spec. I did the math and it would have pushed the output down considerably. Ski still ran the same - glad I didn't pay the $1100 for the dealer to replace.
I took it to another shop. Plugged up the computer, said an injector related code would pop occasionally, but the ski never ran bad on the trailer. He cleaned the injectors with cleaner, so not a true clean and balance/check, and the codes stopped popping. Ran great. The 100% gas smelled funny, which had only been in the tank for 3 weeks, and came from a very new and reputable gas station... but I had him drain it anyway. Ran FANTASTIC for 3 minutes. It actually turned more RPM's than it ever had, and I gained about 3mph, which was awesome. Until it loaded up and fouled the plugs and ran like junk again.
The last shop said that the injector cleaning may have been just enough of a fix to get it going. I can't understand why I can run it for 3 minutes every time until it is good and warm, then it sucks wind. The thing ran fine for the mechanic for 15 minutes with no load.
I've considered buying a used rail/injectors/etc for testing - new injectors are $250 each, and I can get a used setup from ebay for $200. I'm not sure how reliable some used equipment would be, but I may determine quickly if something is right/wrong.
I'm at the guessing stage now, so any help or suggestions are greatly appreciated.
