Sprailfire340
New to pwc and 4 strokes in general. Recently purchased an 02 gtx 4-tec with less than 70 hrs on it. Acts like it is fouling plugs, but have replaced plugs several times with the same result. Must be something else.
Symptons - start cold (day or 2 of non-use) and it will idle and respond to throttle immediately, like it should. Upon engine warming (slighty) it will only respond under max throttle and at high rpm. Bringing it back to idle and then trying to go it only fires on 1 or 2 cylinders until max rpms and aprox 30+mph reached. Then non-firing cylinders will kick in and max acceleration is reached.
Any suggestions? Stator, coils, plugs???? Plugs are cheap, but would like to have some advice before I start replacing more costly parts.
Thanks for your time.
MJE
MJE
