2001 Challenger 1800 240 EFI. Hey all. I ran into a problem over the 4th of July weekend. I purchased the boat used about 2 weeks ago. The boat ran very well on my test drive, and ran fine a couple times since until over the weekend. I was running the boat at wot and the boat just suddenly died like I pulled the lanyard. I couldn't get it to fire back up. All electronics worked and I was getting the proper "start beep." The starter would pop up and hit the flywheel but wouldn't kick the engine over. After getting towed back to the area near the boat launch I figured I would give it one more try (about 25-30 minutes later). Fired right up, and as I gave it throttle to get to the launch, it died again. Seemed to do ok in idle until I throttled up a bit. :ack:
This problem seems to be the exact definition of a bad or stuck anti-siphon valve. Problem is, the previous owner had it "replaced" but with my examining they did not put one in. They just replaced the hoses and didn't install new one.
After calling mercury, they told me that it may be bad gas. I guess my question is, can bad gas cause me to die at wot? and what else can anyone suggest it may be?
Prior to this happening, I replaced all the plugs, the water separating filter, the inline fuel filter, and the baffle assembly filter. Any help would be great. Thanks
