68ragtop
Hi Guys, Do you know if the flywheel housing from a white 580 engine will fit a yellow 580 block? I picked up another a pair of skis that need some work. one is a tired looking 89 that seems to run pretty well. 150psi each side, cylinders look nice using a borescope. The other is a 93 with a scattered engine, but is in nice cosmetic condition. In comparing the two machines, the 93 seems to have quite a few improvements with the electronics, fuel management & drive shaft seal setup.
What I would like to do is put the yellow engine in place of the white. I know based on my forum searches most guys say switch all the electronics & be done with it, however I would like to keep the 93 electronics in place. I noticed the block has some differences & wasn't sure if the white flywheel housing & stator would bolt onto the yellow engine. I assume the flywheel will swap seeing the crankshaft are interchangeable.
Any thoughts?
Carl
Any thoughts?
Carl
