Octane debate
Ok Snipe and I are having a debate about the affects of octane levels in the 2 stroke engines, so if anyone would like to add their thoughts or opinions we would love to hear them.
I should also mention that I am referring to pump gas that you can get at any corner station typically ranging from an 87 to a 94 octane rating, as some but not all race fuels have additives that raise the "heat or energy units" of the fuel which could bring up combustion chamber temperatures and cause damage to an engine that is not purpose built for the application.
I am a strong believer, and all of the reading I have done suggest that there is no link between to a high octane rating and engine damage. The reason for this is octane as a hydrocarbon does not contain any higher energy levels than other hydrocarbon elements, in fact the structure of it forces it to burn slower at a more controlled rate, and resist the tendency to combust upon compression.
I did look through some of the Sea-Doo manuals for the 2 strokes, and agree that they recommend 87 octane. I don't feel they are suggesting that this would be the maximum that you could safely burn, but more of a guideline to follow. All of the dirt bikes, quads, and even my Utopia with its 2 stroke Mercury have listed the octane requirement as a "minimum" so I am puzzled as to why rotax chose to just put the number 87 with no minimum or maximum behind it.
The outboard manuals that I read chapters of online, even went as far as to suggest that if the engine is being used for commercial work or towing to consider using a fuel with a higher (87-91) octane rating.
PS: I am not suggesting that you should run a higher octane fuel, just that it will in no way harm the engine. Premium fuel for the most part is a complete waste of money unless your engine is designed with it in mind, such as the supercharged 4Tecs.
Here are some of our thoughts so far.
Aaron:cheers:
Re: Octane and the 2 stroke
Quote:
Originally Posted by rookie101
Sorry Louis but 2 or 4 stroke does not matter when it comes to the octane rating. You are right that too hot a plug will destroy or shorten the life of an engine, but the only thing too much octane will hurt is your wallet.
I have been a licensed automotive mechanic for a lot of years, and in Canada we have to go to school in order to get our license. One of the things we had to take was understanding fuel make up and how it affects an engine.
I could not find any articals that delt specifically with Sea-Doos, but here is what I could find.
Aaron
This is from VP racing fuels.
Two-strokes stand to benefit more from higher octane fuel than four-strokes. The design of a two-stroke’s exhaust pipe (expansion chamber) keeps more heat backed-up against the cylinder and creates the potential for hot spots that could lead to detonation.
Here is one about Rotax 2 strokes. (I know it's aircraft not watercraft)
Diagnosing Rotax 2 stroke aircraft engine piston failure from detonation, or pre-ignition.
2 2A
Seized Pistons - (Ref: 2 & 2A)
The piston shows yellow spots on the dome and seizure marks on the skirt but there is no sign of metal aluminum.
If you inspect an engine and find yellow or yellow-orange deposits on the piston dome, that engine has experienced an abnormal combustion condition known as detonation. In this situation, combustion begins normally with ignition from the spark plug but as the flame front moves across the combustion chamber, rather than burning smoothly, the unburned portion of the charge spontaneously ignites. This results in extremely high temperatures and a shock wave heard as "pinging." What has happened is combustion has been completed in about 29 degrees of crankshaft rotation instead of the normal 50.
The oxide of calcium, an element found in 2 - stroke oil additives, is normally near white in colour. At temperature very near that of the melting point of the piston, the oxide will change colour from white to yellow-orange and is an indicator that the engine was overheated. The excessive heat results in rapid piston expansion and possible failure of the lubrication film.
Possible causes:
"Too low an octane fuel used or fuel with too much alcohol used"
jetting too lean or failure of the fuel system, i.e., clogged fuel line or filter, fuel tank not venting, problem with fuel pump, carburetor, air leak into crankcase
spark plug heat range too hot
ignition timing too far advanced, possible failure of the c.d. amplifier box
restricted exhaust system: back pressure too high
overheated, loosely-installed spark plug
Seadoosnipe Wrote:
Aaron, I addressed your post in that thread on the fuel. You are completely correct, there is very little that can affect the fuel rating. Once it's 87 octane, it stays that way, though over the course of about 1 month, it will lose one percentage of it's octance rating.
I too, had to go to school on fuel oil. Mostly for the purpose of testing the composition, flashpoint, properities and bottom sediment and water.
In the end, I would like to understand why Rotax recommends 87 octane in their 2 stroke engines. The 89 octane is only processed a bit more to achieve that rating..........so, ?........? I'm left with some questions.
In the one thing that I was studying was cooling of the 2 stroke engines. We do not burn all our fuel in the 2 strokes. There is a percentage left over for lubrication.
I also read that the engineers for Rotax have not determined 100% the reason detonation occurs in our engines.......
PLease feel free to debate that thread in the forum. I look forward to reading your research and your opinions.........
Louis
