H hohenberger4 New Member May 6, 2020 #1 My 99 XP had a new throttle cable installed, as old one was sticking. Now the fully released throttle wont go back to idle. Any suggestions?
mikidymac Moderator Staff member Moderator May 8, 2020 #2 First make sure you have it in the correct hole in the throttle arm on the carb. Are you sure it is the correct cable?
IDoSeaDoo Well-Known Member May 8, 2020 #3 Check the carb and see if it's sticking for some reason. Could it be the finger lever? Not too many points of failure here. First time I hear of a throttle sticking.
