Travisgg
Hey all seadoos running pretty good I've got a 1996 GTX 787. Done a lot of reading on the forum here it sounds like a wear ring issue but I just put in a new WSM ring... Clearance looks pretty similar to the one I just took out maybe get 0.4 to 0.5 of a millimeter between impeller and wear ring with my feeler gauge. Basically when I punch it from a stop it does start moving decently, but is hitting 7000 RPM and just feels like the tires are spinning and then it really grabs after a bit. It always comes up to plane no problem. Just feels like it's missing a little bit of traction at the start. It came with a stainless steel solas prop I believe. Every other speed no problem, just when you punch it, maxes RPM and spins the tires for a little bit but is still having forward momentum during this time just doesn't grab hard for a few seconds into it.
For comparison I've got a 1994 GTX 657 and when you punch it it feels like it's got traction all the way from low end to top end.
I think that prop is just messing with it?
