davemath
So I went the route of a 1mm over bore to fix the OEM piston ring and RAVE crash scoring on my 951 RX DI. I bought the WSM platinum pistons and their WSM top-end gasket kit. I put it all together by mimicking the installation on the parts from what I removed from the OEM head on the ski.
I can't find for the life of me find a parts list or description of what is used for the top-end gasket kit. The big gaskets are obvious, but the smaller o-rings are my "what are they" question.
I'm assuming some of these smaller ones are for the RAVE. But do some go on the head studs on the engine? I didn't remove any from the OEM setup, so my initial thought was no.
I installed the cylinders with copper spray on the cylinder gasket and with nothing on the head gasket, plus not using any of the small o-rings on the head bolts. She runs well with the over bore and RAVE shaving. So a mechanical success.
Here's the bad: Inside the engine, I have a "shiny head" (photo) along with water crystalizing (photo) on the spark plugs and some water droplets on the RAVE (yep, another photo) valves. So I've got an issue with water ingress.
I've watched Youtube videos an searched for info on the forums here, and I'm not finding anything detailed on the process for a top-end work for the head gasket to get a good water-free seal.
Any tips on where to point me or ideas? THANK YOU!
