Wow Really another problem....
Jay_Crims0n
OK So I have two 93 SPI's.
The First one has been Running Really Great everytime I took it out.
The second one runs good when it wants too.
Ok So after a few good sized jumps the first one started Hobbling.
I will floor it and it will run for a bit then die off then run for a bit.
The second one has had the same problem as the first one but it has been like that for awhile. starts and idles fine, but when I floor it it will run then bog down and sometimes die.
On the second one this is what was replaced.
1. Sparkplugs
2. Carbs rebuilt
3. some fuel lines changed
4. Fuel Baffle replaced
5. old fuel out
on the first one (the one that was funning great)
1. Sparkpulgs
2. Carbs rebuilt
3. old fuel removed
So how is it I have the same problem with both?
Any ideas on what the problem is?
also I pulled the plugs (agian) and they look decent
smell abit like fuel but nothing really.
AnyIdeas?
That to me sounds like a fueling problem. Or maybe a lack there of. What kind of fuel are you using? Did you check to see that the fuel lines all flow freely and have you tried the fuel selector on both ON and RES?
Yeah it runs crappy on both res and On.
I have replaced a few lines but with no luck...
I have also cleaned the fuel filters too..
Still nothing....
