Will a 2011 rxt driveshaft fit on a 2010 rxt machine?
brandon.johns2
Hi guys, I recently stripped my 2010 rxt 215 driveshaft. I was wondering if a 2011 driveshaft is the better way to go with the c clip? I herd brp 2009-2010 driveshaft sucks and fails early. If I were to put the 2011 in would I have to change anything to make it fit? Also if I have to get a new impeller, what pitch should I run on a 2010 rxt 215
I had the same issue on my 2010 Rxt 215, luckily it was covered by warranty. The replacement was the 2011 drive shaft with the c-clip. Make sure you verify that you get all the updated part numbers.
Would mine still be covered? Also would you go with the sbt upgrade? It's cheaper by like 300$
