Help! Late last year, my rotary valve seized due to oil starvation. I pulled the shaft and replaced the brass gear, cleaned up all the parts as best I could and reassembled. It scrubbed again . . . no surprise. So over the winter, I did a full teardown:
- Cleaned all the brass shavings out
- Made sure the RV block face was flat (some remaining grooves and dings but surface is flat and smooth)
- Cleaned up the RV cover (a couple of small grooves but very flat and smooth)
- Bought a new OEM Rotary Valve
- RV Shaft Spline had the usual groove at the plate location, but not deep.
- Oil flow from the Mikuni pump looked fine. Oil lines were primed with oil before starting
The rebuild looked real good . . . everything turning smoothly. Once in the water, the engine started and idled fine. I got on plane easily. After only a couple minutes above idle though, it started losing power again. After cooldown, it started and idled, but I did notice an occasional misfire or predetonation that was never there before. Cooling flow out the stern fitting was pretty good, but not great. I removed the RV cover and found that the RV had scrubbed again! All the parts were plenty oily. The scrubbing happened only on the outside . . . on the RV Cover, not the block.
I’m at a loss. By only hypothesis is that the plate position is more sensitive to the spline grooving than I thought, and that I did not seat the RV shaft far enough into the block - which may tend to center the RV too close to the RV Cover?. The snap ring went on fine, but it is touching the seal.
Any thoughts would be greatly appreciated. I think the engine rebuild is still fine. But I don’t know how to get the RV to run free again. Thanks,
Kevin
1999 SeaDoo GTX-RFI
Kevin
1999 SeaDoo GTX-RFI
