artr
Hello. I just started the season and noticed a mild whine from behind when cruising at 5000 rpm on my 96 GTX. Seems to be rpm dependent. Do not hear it at idle or other speeds. Do not feel any abnormal vibrations. Before I launched it I did a lot of normal maintenance. I greased the PTO fitting, checked the jet pump oil for water and condition of oil and pressure tested it the best I could with a pop-off tester I had made (the pump was replaced with a used one mid last season and changed oil then). I also installed a neoprene seal on the jet pump in an attempt to cure some cavitation on hard acceleration from a dead stop but that did not cure the problem (but it did slightly modify the position of the jet pump from last year). I did other normal things like clean the RAVE valves and changed oil filter and plugs that I don't think would cause a whine. Because I changed the oil filter, I ran it on the trailer with a hose for a couple of minutes to check oil flow and did not notice any abnormal sounds or vibrations then. What are things to check in the water? Because the sound is not real noticeable and seems to be at a specific RPM, is this something others have experienced and have let go for a while? Thanks for any advice on the subject.
