I see what you mean. I just spent an hour researching them and that's a confusing ass topic. It doesn't help that companies like Solas have product descriptions for every product that they make that just say "get the all new right from the lab patented amazing design in ultimate acceleration and speed performance". Then the wiki says go up/down for holeshot/top end. Like just tell me what the literal difference is between your product lines. Concord/X-Prop(why isn't it X-Imp?)/Dynaflow etc... Fuck
The "rebuild" kits show like 4 rings, etc with the bearings, but I haven't found the seal at the bearing/driveshaft behind the impeller. It would probably be easier with an actual SeaDoo dealer/site that I can get exploded views that far back with part numbers. You'd think a pump seal kit would cover some seals... There's not a dealer here, and sites like SBT are inconsistent. Last time I pulled up just OEM wear rings they had them but the delivery was over 2 weeks out, so I decided to look around and when I got back to them their entire listing was different and only showed a white delrin ring. It's been a bit of a nightmare.
I found a few sites that list the 1997½ skis but it's just more confusing generally. As long as it's not electrical, I can get away with 1996 parts a lot, sometimes it's 98. I'm gonna go pull apart an actual 96 today and see what's inside. It's gotta all use that plate, it's the same hull. Oh, my upper is a pearl color. It's not exactly white, but it's not silver unless it's a really light silver. It's more like a metallic white but... Yeah more silver.
